4" crank in a 400 small block
Old May 13, 2001 | 08:31 PM
StCr19's Avatar
Car: 1991 Galant VR4
Engine: 2.0L 4G63 Turbo
Transmission: 5sp transaxle/transfer case
Can a stock, production 400 block be machined to accept a 3.875" or 4.000" stroke crankshaft? Also, what is this process called?
Old May 13, 2001 | 09:55 PM
406 S10 Man's Avatar
Car: 1971 Corvette
Engine: 6.0 LS1 L92 heads sheet metal etc.
Transmission: M21 4-speed
Axle/Gears: 3.36
yes. th process is called "get out your grinder". it is a major pita to grind the block for the crank to fit and that is just the beginning. do a search for 4" and you should find a few threads. we discussed this not too long ago.
88 S10
Dropped 3/4
18" Boyd Coddington Timeless 5s
406 balanced with 6" Eagle H-beam rods, 10.25:1 JE SRP pistons, Comp 284XE cam; 240/246 @.050, .507/.510, Dart 200cc Ironeagle heads, Victor Jr. intake, Holley 750 vac sec.
12.20 @ 115.25 mph
theshackle
Mar 5, 2017 06:37 PM
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
camaro71633
Sep 1, 2015 10:24 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
