initial start up
Old Sep 22, 2004 | 05:18 AM
icarus402001's Avatar
initial start up
I'm driving a 92RS. When starting cold, the engine cranks 12-16 times then fires up. It runs as great as a mostly stock LO3 with a recent tune up will. Follow up starts throughout the day and evening wil be 2-3 cranks, then fire up. No big deal, but I figure with my open element the fuel left in the system just evaporates. I don'tsee my injectors dripping after shutdown. There seems to be a 5 or 6 hour window for the start to take longer. Any ideas?
Old Sep 22, 2004 | 08:28 AM
bobsroc's Avatar
Car: 1987 IROCZ
Does your fuel pump run when you turn the key to run for a couple of seconds before you start? If it doesn't I would check the FP relay. Or maybe the check valve in the fuel pump is defective letting the fuel pressure bleed off to 0 PSI after it sits for some time.
Old Sep 24, 2004 | 05:16 AM
Thanks. I'll look into therelay tonight.
theshackle
Sep 17, 2020 08:26 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
bellez77
Sep 5, 2015 08:39 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
