Broken rear end bolt
I was changing the rear differential fluid in my 91 cheverolet p/u, its a 10 bolt, and i was torqing the bolts back on and the top right one just snapped off. How would i go about removing it?
go to a parts store and get an easy out, relatively small diameter. the instructions will tell you what sized drill bit u need. drill the center of the bolt out (not too deep, only want to drill the bolt not the housing) then tighten the easy out in the hole (it's reverse thread) so you'll be turning it counter clockwise. eventually it will bottom out and begin to turn the bolt out....get a new bolt and you're done!
85 Z28- 350, Comp 262, Edelbrock Performer intake, Edelbrock 600 cfm carb and Edelbrock cat back, Summit
headers and vette servo
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
headers and vette servo-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
