EGR & Solenoid
Old May 15, 2001 | 04:01 PM
Steve89GTA's Avatar
EGR & Solenoid
The solenoid controls the EGR's movement? Can this cause a low RPM bog/hesitation? How can I verify that the EGR solenoid is good and is working? Are they expensive? How can I eliminate the EGR (without tearing off the plenum) to see if it's causing the hesitation problem...disconnect and plug the vac lines that go to the solenoid?/EGR?. Would the solenoid set a code if it were screwed?
Thanks for all your help, this problem has been killing me for over a year now. Car runs great otherwise and has a steady idle..it's just past idle that's the problem and up to 1900rpm or so.
Please help me.
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
New Fuel Pump!
Autometer Vac+Oil Temp
2000 Yamaha R1 150hp 385ibs
Old May 16, 2001 | 11:55 AM
Steve89GTA's Avatar
btt
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
