compression
Old May 17, 2001 | 12:59 PM
rdayz28's Avatar
compression
just put a set of 305 vortecs on my 84 z28 alot better throttle response and gas milage my question is before compression guage read about 130 after it read 160psi what is compression ratio and can you figure it out just by the gauge it has stock pistons with the vortec heads 58cc chambers
Old May 17, 2001 | 01:17 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You can't figure it out from the gauge. Too many factors influence that, not the least of which is the condition of the valve job, which went from old and tired to brand-new.
If you took off a set of the stock 305 heads, 416 casting, then your static compression is pretty much unchanged. The chamber size is the same on both types of heads.
ICON Motorsports
Old May 17, 2001 | 01:41 PM
MatthewH's Avatar
rday,
Where did you get Vortecs with 58 cc chambers? Did you have them milled from 64 cc? How much were they?
Thanks,
Matt
Old May 18, 2001 | 01:05 PM
rdayz28's Avatar
<font face="Verdana, Arial" size="2">Originally posted by MatthewH:
rday,
Thanks,
Matt
</font>
i got them off ebay for about 300 dollarsthey are out of a 96 chevy pickup no they wernt milled
Old May 20, 2001 | 01:47 AM
jaretz28's Avatar
Well if your heads were originally 64 cc combustion chambers, and had 9.5 to 1 compression then shrinking them to 58 cc my educated guess would be ABOUT 10 to 1.
FormulasOnly
Jul 23, 2018 08:47 AM
69GTOby
Apr 18, 2016 02:34 PM
Nervous2
Oct 8, 2015 10:53 PM
Jonas Earl
Sep 27, 2015 07:39 AM
WhteRbt
Sep 21, 2015 09:48 AM
