Heat/AC Question
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
Heat/AC Question
**I couldn't find a board specifically for this question so if I'm in the wrong board please move this post**
The weather has been getting a little bit colder so I've had to fire up the defrost/heater. I've noticed that no matter where I put the selector(VENT, BI-LEV, HEATER, DEFOG), it does not affect the air coming out. It seems like the air is only coming out of the vents and just a little bit through the defroster ducts. Again, it does matter which option I select. The temperature control works just fine. Is there anything I can do to get my heating system to cooperate? Thanks.
85 Z-28 LG69, Performer Intake, Holley 600 w/e-choke, no smog, no cat, dynomax exhaust, B&M shift kit.
Transmission: 4L80E/4L80E
You either have insufficient vacuum to operate the heater door servos, or something fell in there and is jamming the works.
Or, something is corroded/frozen in place.
I'll bet vacuum, though.
