Timing Questions
Old Oct 13, 2004 | 10:59 PM
My91RSCamaro's Avatar
Car: 1991 Camaro.
Engine: 305 TBI
Timing Questions
I have a 91 RS, 305tbi, 700R4.
Mods- K&N Open element, flow through lid.
All new Ignition system, oem. Except for the in cap ignition moduel.
High-Flow cat.
Flowmaster cat back 40series.
Hypertech thermomaster chip.
I curently have the timing set at 0degrees base timing with out computer control.
With computer control I have about 12degrees base timing. Does this sound good or should I add some base timing? <--- Main Question.
I just got back from the track tonight here are the results.
Reaction= 0.361
60ft= 2.31
1/8= 6.676
ET= 16.005
I was leaving the line at an idle. still had eather light-mild tire spin or medium wheel hop.
The only suspension mods are a whole new front end, and a Polygraphite tranny mount.
I am running on 235/60/r15
Old Oct 13, 2004 | 11:49 PM
25THRSS's Avatar
what were your trap speeds?
Old Oct 14, 2004 | 06:56 AM
mudflap1989's Avatar
I believe the your 1/8 times are wrong too.
Old Oct 14, 2004 | 09:16 AM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
I don't get how people have wheel hop or traction problems when they run 16's... I was running 15.9's and I had NO Traction Problems, I MEAN THEY DIDN'T EVEN CHURP, I just went.
My 60fts were 2.29, fastest 1/4 was 15.923 at 84.59. I am only running 225/60/15 tires and their super cheapies from some little tire place.
Now back to the question, my friend has a 90 RS with TBI and a Stage 2 chip, he runs between 6-8 degrees base, where the chip calls for 0 degrees base, so he's adding a bit of timing, he said it helped his times quite a bit... So as long as you stay away from Detonation or Ping, I'm sure it couldn't hurt to run a little more timing.
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
