Clutch fork pivot adjustment
Old May 21, 2001 | 09:51 PM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
Can the pivot ball on the bellhousing for a
T5 transmission be adjusted? I noticed when
putting the new clutch assembly together that the old and new pressure plates were
slightly different thickness. So I might need to adjust something. On a hydraulic clutch nothing looks adjustable except that screw in pivot ball ?
Tom K.
84 Z-28 M5 305 L69 HO
pulleys,coil,3:73(stock)
Jet chip, fan switch,
Al dshaft,1.6 rockers,
LCAs and brackets,BFG DRs
14.20 @ 96.74 2.02 60ft
Old May 21, 2001 | 11:26 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
The pivot ball is not adjustable.
On a hydraulic clutch, the "free play" at the pedal is usually adjustable. (between the pedal and the clutch master.)
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Old Aug 27, 2004 | 10:35 PM
Dan86Z28's Avatar
SOrry to bring this TTT, but does that mean that that pivot ball should be screwed all the way into the bellhousing>
Old Aug 28, 2004 | 04:06 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Yes; the hydraulic system is self-adjusting.
mygta87
Sep 14, 2015 10:36 PM
jtwoods4
Sep 3, 2015 05:39 PM
tonys91rs
Sep 2, 2015 07:07 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
