Deleting heater core
Old Oct 26, 2004 | 04:09 PM
galletti's Avatar
Car: 1988 IROC Convertible
Hello,
I've searched the board and found a lot of info about replacing the heater core but nothing on removing it completely. I need to know if I can remove the whole box that holds it without affecting the ac system. Also, what kind of rerouting would I need for the hoses under the hood? Do I only need to run a hose from the intake to the water pump? Any help would be greatly appreciated. Thanks.
Old Oct 26, 2004 | 04:14 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Well I'm not real sure but if you remove the box I would think it would effect your a/c.
As far as rerouting hoses, take the two hoses that go into the fire wall to the heater core and connect them together. That's how I have my T/A right now. Heater core went out a few months ago.
Old Oct 26, 2004 | 05:12 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If you are removing the heater core, like I did, you don't need to re-route any hoses. All I did was put brass plugs in place of the outlets for the heater. Theres one in the water pump, and one in the intake manifold.
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
