How much does gears play a role in acceloration?
Old Oct 28, 2004 | 09:56 PM
CamZ28's Avatar
Car: 86 Z28
Engine: 383
Transmission: built 700r4
Well, I got my 383 in my 86 z28 and it runs great. But it does have the ***** to the wall acceloration as I though it would.
Factors: I have a 2800 stall converter. And a stock highway gear rear end.
the converter is matched with the cam. so would alot of the lack of acceloration come from **** poor gears?
Old Oct 28, 2004 | 10:08 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Yes, put more so from a bad, or lack of tune.
Gears multiply torque. So if your motors making 300 ft-lbs torque at 2800rpm and first gear is say 2.50 and your rear is 2.77. You are seeing 300*2.5*2.73=2050 ft-lbs at the rear assuming no losses. Now if you have 3.73 gears your making 300*2.5*3.73=2800 ft-lbs. A 37% increase in rear TQ.
Old Oct 28, 2004 | 10:10 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Gears can make a huge difference. 3.73 will pin you back alot more than 2.73 for example.
Old Oct 28, 2004 | 10:16 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
You should match rear gears to the cam as well. If you get a larger cam, you up the gears to help on acceleration from lack of low end grunt. 3.73's are an all around great street gear for a moderatly cammed engine, IMO.
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
dbrochard
Sep 19, 2015 08:13 PM
84 TA NV
Sep 6, 2015 08:02 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
