thanks 89 350 TPI
Check the resistance of the sensor at a given temperature:
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Later,
Vader
I dont have an OHM meter but I have a good scanner. Will that work?Member
The scanner should work just as well. Compare the intake sensor with cts when engine cold and they should be same if engine is totally cold. Or go buy a meter.
Iroc Z28 with several mods for domination of autocross courses. BFG T/A R1s for the courses and Yokahama AVS Intermediates for the street.
