how to get the most out of 355 SHORTBLOCK??
Old Nov 2, 2004 | 09:12 PM
86interceptor's Avatar
Car: 86 Z-28 Police Interceptor
Engine: 305 but building a 350
Transmission: 700r4 with shift kit
I tried to delet it but I can't
I
Old Nov 2, 2004 | 09:24 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
You don't really need 2 consecutive threads asking the same thing.
How do you get 400 hp out of a 350? Simple, get rid of these:
fresh set of 882
Those are smogger crap POS disgraces of cast iron. They have large 76cc smogger crap POS combustion chambers that kill compression. They have thin casting walls in critical areas and some are prone to cracking (later castings, there ARE HD castings out there, but either way, smogger crap.)
Get a better set of heads. Then go from there.
Once you get a better set of heads, RPM series intake and a cam. If you get a cam, the best thing you can do is get a stall.
Other than that, here's how it goes: the 882's have large chambers that kill compression. Any aftermarket cam that gets 400 hp out of a 350, requires more like 9-10:1 compression. Anything less and the cam reduces cylinder pressure which hurts torque. That makes the car no fun on the street.
On the flip side, any cam that can use the factory stall speed, probably won't make 400 hp. Increasing the stall speed would be a wise choice.
It's your call.
Old Nov 2, 2004 | 09:31 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Yeah whats the deal, 2 threads? I said pretty much the same thing in your other before i saw this one.
Old Nov 2, 2004 | 10:06 PM
sorry about the 2 threads I am new to this site. In the other site I am a member of they barked at me for asking to many ?'s in the same post, go figure lol
Old Nov 2, 2004 | 10:38 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Must be a F O R D site.
Old Nov 2, 2004 | 10:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you keep the theme the same, go ahead and continue the thread.
We'll keep the discussion on the other one now.
codeysabatini
Nov 10, 2015 04:07 PM
darwinprice
17
Oct 11, 2015 11:51 PM
skinny z
Oct 5, 2015 06:23 PM
BLK87Z
Sep 18, 2015 11:29 PM
anesthes
Sep 18, 2015 12:34 PM
