Poor Performance at Startup
Old Nov 10, 2004 | 09:21 PM
clewis's Avatar
Car: 1985 IROC-Z
Engine: 305 Tuned Port Injection
My 85 IROC is running rough when I first start it up. After running for a few minutes, it smooths out. I can even feel it through the gas pedal. It seems like it's running on 7 cylinders. Any suggestions on what might be going on?
Old Nov 11, 2004 | 04:26 AM
ede's Avatar
ede
maybe it's running on 7 cylinders since you said that's what it acts like. have you tried trouble shooting to see if you do have a dead hole? WAG but i think i'd look at the choke.
Old Nov 11, 2004 | 08:42 AM
clewis's Avatar
Car: 1985 IROC-Z
I think it could be associated with the choke, it seems like it could also be something dealing with fuel delivery. When my car was just a month old, it fouled a couple of the injectors and utlimately they all had to be replaced. The symptoms it has now are somewhat similar to how it was performing with a fouled injector. The one difference here is that the problem goes away as the engine reaches normal operating temps.
How do I troubleshoot the choke to try and rule that out?
Old Nov 11, 2004 | 10:51 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The tuned port injection setup doesn't use a choke.
Maybe CTS related?
Old Nov 11, 2004 | 11:09 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Does it only stumble around only when you first start it up?
I had leaky fuel injectors and when id start the car, it would stumble for the first 10 seconds until it cleaned itself out.
Old Nov 11, 2004 | 06:01 PM
clewis's Avatar
Car: 1985 IROC-Z
Okay, I'm not sure what CTS is. Could you decipher that for me?
Secondly, sometimes it stumbles for just a few seconds, other times, it runs like that for a few miles before straightening itself out.
Old Nov 11, 2004 | 09:35 PM
Car: 1988 IROC-Z
Engine: 427 SBC
CTS = Coolant temperature sensor.
https://www.thirdgen.org/techbb2/att...postid=2036300
Old Nov 11, 2004 | 10:12 PM
clewis's Avatar
Car: 1985 IROC-Z
Well I pulled the plugs and they all looked normal with the exception of the #1 cylinder. It was wet and smelled like gas. I haven't even started it up today. I shut it off after getting home yesterday after work, around 4:30 p.m. I think that this may be the source of my problem. Now, what could be causing this?
I replaced the CTS a couple of years ago.
Old Nov 11, 2004 | 10:25 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Sounds like a leaky injector on #1. Get a pressure guage, prime the fuel system, and see if the pressure leaks down a little at a time until 0 psi watching the guage... it make take a few minutes, but that would be my guess for the gas...
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
