Fuel system on '84 Camaro
Old May 30, 2001 | 07:27 PM
GlenYappa's Avatar
I am building a mildly SCed 350 for my '84 Camaro. I currently have the entire fule system (tank and all) off the car. What changes do people recommend for the engine that I am building. Would I benefit from a larger diameter fuel line than I have now? Recommendations for type of fuel pump? Is there anything I need to do to the pickup in the tank besides replace with a new one?
Thanks,
Glen
Old May 31, 2001 | 10:34 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I would use the factory fuel line, its probably big enough unless you are building a 450 horsepower engine or more. You will definately need to upgrade your fuel pump, the stock mechanical pump won't be enough to feed your new 350. I really like the Carter electric pumps, they are quieter than the Holly's and are internally regulated. I have the 100gph carter and it works great. Or if you don't want to go through the trouble of installing an electric get a high flow mechanical pump.
best 1/4 mile so far: 13.4 @ 101mph
84 Camaro 305 ported & milled heads, 3 angle valve job, Edelbrock Performer RPM intake, Hedman full length headers, Accell ignition, Crane 274H cam, B&M 700R-4, 3000 stall speed, 4.10 gear,
M/T ET street tires
visit my website at http://www.geocities.com/jbenge/page1.html
Old May 31, 2001 | 12:34 PM
GlenYappa's Avatar
I was definitely going to upgrade the mechanical pump but now I am thinking an electric pump would be good. What all do I have to change to go electric?
Old May 31, 2001 | 05:28 PM
jbenge's Avatar
Its not too hard converting to an electric fuel pump but it can be a little time consuming. First get a block off plate to cover the hole where the mechanical pump was. You will have to cut and splice into the fuel line that used to go to the mech. pump and run new line up to the carb. The best place I've found to mount an electric pump on a thirdgen is back by the tank where the undercarriage slopes up where the backseat is. Unhook the fuel line that comes out of tank and connect it to your pump. Depending on what kind of pump you get you may need a regulator and return line.
The easiest way to wire the new pump is to buy a wiring kit from painless. It comes with a relay, circuit breaker and wiring diagram. You may want to power the relay with the ignition switch and a manual switch that way if you want to turn the key on without pumping fuel you can, also makes a nice anti-theft device if you hide the switch.
M/T ET street tires
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Grant2k
Jul 10, 2018 04:01 PM
Caspar
Jun 19, 2016 11:19 PM
