Exhaust leak cause smog failure???
Old Nov 18, 2004 | 12:37 PM
92GTA's Avatar
I've got an exhaust on my #2 header flange and I'm up for smog in like 2 weeks and I really don't fell like screwing with it since I'll be installing new heads in about a month or so anyway.
It's very obvious on cold start when it's like 50 degrees, but when the engine is at full running it's not noticable unless you are under the hood and know where it is, which the smog tech will be under the hood.
My question, since it's this small once warmed up, will it be sucking in enough air to increase my o2 amount enough to cause me to fail?
Old Nov 20, 2004 | 11:58 AM
Vader's Avatar
If the leak is on the #2 hole, it shouldn't affect the O² sensor, as long as the sensor is in the stock location (on the opposite bank).
Old Nov 20, 2004 | 01:37 PM
92GTA's Avatar
True however what if it's sucking in enough air into the exhaust to cause too much o2 coming out the tailpipe? See in CA you fail for having too much plain oxygen in your exhaust. I know it won't effect my BLM's....
Old Nov 20, 2004 | 03:23 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
fail for having too much o2?
now isn't that a crock of cow dung
Old Nov 20, 2004 | 06:40 PM
safemode's Avatar
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
all smog testing is a crock.
Old Nov 22, 2004 | 12:49 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
No, you'll fail for having too much NOx. That's not pure O2. NOx is when you are too lean in your chambers and the temps get too high. EGR helps this as does retarding timing.
transaero
Aug 31, 2015 01:14 AM
TheExaminer
Aug 26, 2015 04:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
mustangman65_79
Aug 7, 2015 09:55 PM
drathaar907
Aug 6, 2015 04:20 PM
