EGR question.
Old Nov 20, 2004 | 10:22 PM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
EGR question.
I have an 87 LB9 5 speed. With the EGR connected it stumbles a bit when cruizing or medium-low throttle. When I disconnect it, it is fine. Should I replace the EGR valve or is the computor opening it at the wrong time and how can I tell which is happening? Thanks in advance..
Old Nov 21, 2004 | 08:45 AM
contactpatch's Avatar
Engine: sbc 350
hint-->
>When I disconnect it, it is fine.<
Old Nov 21, 2004 | 11:21 AM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
Either replace it or block it off. If you block it off, you will need to have it turned off in the computer or else you will get a code 32 all the time. I have mine blocked and get the code all the time, but since I know what it is....i don't worry about it, but if you go this route it would be wise to pull the codes every now and then to make sure there is not something else throwing a code other than EGR.
Old Nov 21, 2004 | 08:50 PM
REALPOWER's Avatar
Transmission: Th350
So it is the EGR valve, not the computer opening it at the wrong time. When I disconnect it (pull the vaccum line off it) I don't get any codes. Maybe its because its an 87.
Old Nov 21, 2004 | 08:52 PM
White91GTA's Avatar
Engine: 5.7L TPI
That would be correct.
Old Nov 23, 2004 | 01:37 PM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Agreed, I did the same thing.
Same darn thing was going on with my 4.3 in my 97 Full size chevy pick up, felt like a constant surge under moderate throttle conditions.
I got some thick Garlok gastet material we use for steam flange gaskets at work, and made a new gasket with only the two bolt holes in it, effectivly using it as a block off plate between the EGR valve and the manifold. I am getting the code 32. Took 3 days to throw the code but it showed up yesterday. I don't care about the code, cause the truck has never run better since I got it 4 months ago.
Old Nov 23, 2004 | 05:31 PM
White91GTA's Avatar
Engine: 5.7L TPI
IIRC, it took about a week before my car finally threw a 32 after blocking off the EGR. If my truck ever starts acting up, I am going to block the EGR off in it too.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
