Even with my new tires
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
how do i know they will fit our cars?
the local shop said $10 to mount a tire to another customer while i was waiting.... so thats $40 for a set, so $80 by thre time the total investment is over. If i can find 4 steel rims for less then 40, maybe otherwise its not worth it...
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Shane, you have a hard time seeing the big picture huh?
Little tidbit of useless knowledge, the thinner the tire, the better it does in the snow, esp. the thick stuff. That's one of the reasons that they had a bit easier time back in the day. The weight of the cars may have helped too.
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
drivin an f-car in the snow isnt hard if you arnt a retard, sure its probably difficult for an inexperienced driver but im sure most of us here have never had a problem, the only real obsticle is the ride height when you have a decent amount of snow on the ground..
Car: 1986 Trans Am
Engine: 305 LB9 TPI
so.... hmmm
where can i find a set of 15" wheels that will fit our cars?
the junkyard around here with lots of thirdgens didn't have any wheels left.... so...
plus they were $20 a pop...
Car: '86 Berlinetta
do the math here... you can get a FWD crap car that still runs (barely) for about 300 dollars... since you have liability coverage, I'm also guessing you have a 500 dollars deductible (I think that's the highest allstate gives).
Now... if you get into an accident you're paying 500 dollars no matter what, unless the damage to the other person's car is less than that.
So... which is better, 300 now... or 500 later?
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Call around for "snow wheels" they are crappy steel wheels. Also the place you call will tell you if the tires will fit. Call tire places, junk yard, used parts places.....
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Originally posted by therckid
so.... hmmm
so.... hmmm
they arent pretty but they will work ...then you can get some tires to mount on them .....right now i got them on the back of my impala to roll it around on ....but the tires are shot..
Car: 1986 Trans Am
Engine: 305 LB9 TPI
$300 now, plus $100 a month in insuance, and we get to be a higher cost, thats why i say a big hell no....
i'll just get me some all season tires buddy or wont goto work the days it snows really badly.
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Originally posted by THEGENERAL
shane i have 2 15" camaro z aluminum rims ill sell you for $20 for the pair you have to come and get them ......
I'll need rears more thrn fronts so...
and also, is it better to get 4 snow tires or just the rears?
are they fronts or rears?
if it were me id only get the rears ...
Car: 1986 Trans Am
Engine: 305 LB9 TPI
hmmm as to my knowledge the front and rears on our car are completely different offsets, so they wont work on either or....
ummm this is something i need to know bro...
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
so which is it??
renting your dads truck
getting all season tires for your 16's
getting snow tires for your 16's
getting snow tires for 15's you dont have
using what you got now
did i miss any??
just learn to drive in the snow its not hard i did it fine my first few times out but i have slid into a curb once turning slow as ****
the rear of the car will not turn on you unless you are giving it gas drive slowwwwwwwww
did i miss any??
You're really having trouble??? I had to drive my Monte in the snow in my first 6 months of driving and had no trouble even on crappy tires. You're car doesn't exactly have monstrous power so the wheels should be spinning too much unless like the guys said-you're hitting the throttle. Even in my LT1 i have no problems with wet weather driving. If i didn't have two other cars that i was trying to get rid of, i'd get a Honda CRX. They get really good gas mileage and they're great in the bad weather not to mention there are tons of them with 5 speed manuals and manual tranny's are better for crappy weather. Think about it and good luck.
It's so tempting to throw away my moderator duties and risk getting banned just to chew you out Shane. Put the keyboard away, call your local garages and tire shops, and tell them you need used snow tires and steel wheels for your car. They do the rest. Christ...
Oh, and yes, PLEASE wash your car with warm water when you get home one day when it's 20 degrees out. PLEASE??! I really want to see the "Why'd my windshield explode?" thread.
maybe someone else can chime in here and solve this delima....LOL
but as said before you would be better off just driving slow and not hammering it when you take off
for crying out loud you only have a 305 and its stock .....LOL
not a powerhouse persay
LOL
Car: 82 Z28
Transmission: TH350
The 15" wheels are all the same, the 16" wheels are different front and rear.
Research d00d. Get off your *** d00d.
Car: Tree Huggers
Engine: Do Not
Haterz!
ME got it, 16's were different front to back, 15's were not. Doesn't matter, because you more than likely will do nothing with this information as well. Go get the rims from General and go get something to put on 'em, or take your car off the road for the winter and buy an escort or taurus as a winter beater, that way you don't pay 'extra' for the second car.
Car: '86 Berlinetta
exactly, Red Devil. Your insurance will be less with the FWD rust bucket than it is for your Firebird... insurance companies see the F-bodies as "Sports Cars" (or atleast that's what mine told me), so yours is going to cost more in insurance.. take it off, replace it with whatever car, and you'll be paying even less.
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
"and also, where should i look for used tires, who sells them in the local area?"
Can this dude do ANYTHING without asking someone else for help?
...how'd your "custom speaker box" work out
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
Hey... where are the pics of your ladies that you promised us last wk??
And we're still waiting to hear how that $200 big block is coming along too.
no no no it would be "d00d iunno why'd my windshield explode?"..
d00d, i jst wasshd my car wth warm watar and the fricking winshiled expodered. Why?
Any way, chalk up one more to the list:
$200 pro street car
Custom box for back of car
Roll cage for looks
Pics of the ladies
shanes tires
shanes tires again
Where will it end?
Car: 1986 Trans Am
Engine: 305 LB9 TPI
well guys after thinking lontg and hard, i'll just deal and we'll see sooner or later what happens to me...
i'll just have to practice really hard...
Thnaks guys and if this dont woprk i'll try and get those snow tires...
Car: 1991 Pontiac Firebird
Engine: 3.1 V6
Transmission: automatic - nothing special
Geez.........I drove mine around on all seasons with no extra weight in the car and had no problems. Even managed to keep her on the road in snow deep enough to scrape the bottom of the car during my second winter of driving it. I just took my time and got every where I needed to go without any problems (actually it was kinda fun when the rear slid around on a couple of occasions). The last few years, I put the car away and drive something else (just because the salt on the roads up here in the Canadian Maritime provinces kills the cars!)
Do yourself a huge favour - at least slap a good set of all seasons (preferably winter) on it
Car: 1986 Trans Am
Engine: 305 LB9 TPI
oh i will try to very soon, i just cant wait until it snows again...
liked the fact that i had to scrap the snow off my car to even get the windshield wipers to move it was cool....the driving part was the scary part....
not used to snow since i'm from florida...
Engine: 3.1 V6
Good luck - you may want to take the car out sometime to an empty parking lot and play around in the snow - get used to the how the car acts in the snow.....I actually had a bit of fun driving mine in the winter, once I got used to how to control the car when it kicked out. I kind of miss it.
Car: 82 Z28
Transmission: TH350
You can't drive with summer only tires, nomatter what people say. They are not talking about your tires, they are talking about all-season or all-season performance, not your summer only tires.
Your gonna die d00d and kill others d00d.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
