How to check for a noisy valve?
Old Jun 4, 2001 | 06:56 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
There is a some knd of a clicking/ticking noise when I step hard on the gas. I think it could be a noisy valve. How do I check for that.
Eg. I am driving 40 mph on the 2 gear(5 spd) and the Rpm's are mid to high but not at the yellow line (5000). When I hit the has it makes that noise for a half a second and then it is normal.
This only happens at high RPM.s
Ps. The car has 100,000 miles, always oil change on time,
Any sugestions would be aappreciated.
89Iroc, 305 TPI, WC T5, 3.08 Posi, Headers, Hooker Y-Pipe, 3 inch over the axle, Flowmaster 80, No Cat, Aluminium Driveshaft, Ported Plenum, Air Foil, K&N, All free mods,
Old Jun 4, 2001 | 04:30 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
are you sure its not pinging? what kind of gas/octane do you use?
86 Camaro with 88 305 LB9 using 86 carb setup, edelbrock performer manifold, 305 S/R Torquer Heads, Hedman Headers, Crane Compucam 2032 edelbrock cat-back, gutted cat, slp underdrive pulley, mallory ignition, 305 h.o dual snorkel air cleaner, hypertech thermomaster chip,160 degree thermostat, 5-speed, 3.23 posi
95 Beretta Z26, 3100 V6, 4 Speed auto, stock
Old Jun 5, 2001 | 06:58 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Whatever it was is gone.
My knock sensor was not pluged in all the way.
Not i can hear that noise.
Thanks 86Z.
deracer
Apr 11, 2016 12:04 AM
backtothe80s
Sep 5, 2015 12:39 AM
mike_c
Aug 27, 2015 04:32 PM
Out-Cast
Aug 17, 2015 10:57 AM
