Is This Right!!!
Old Dec 3, 2004 | 04:11 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Is This Right!!!
I been having oil leaks for awhile so i replaced the driver side vavle cover gasket cause that were i saw oil form under the car. anyways the oil is still there and i looked at the oil pressure sending unit and there is oil where the connecter hooks up to. this this right. help this could stop my leak!!!!
Old Dec 3, 2004 | 04:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If you see oil there, it leaks. Replace it.
Old Dec 3, 2004 | 04:57 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Could be the intake gasket also.
Old Dec 4, 2004 | 12:14 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
well if i pull of the 3 pin connector from the unit there is oil in there. i dont think thats right, i think im just going to replace that thing. Aslo how do you get it off? do i turn it a or somthing
Old Dec 4, 2004 | 07:21 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
When you buy the new one you'll see how it goes in, and the size of wrench you'll need.
