Noisy valve or ignition . . .
Old Jun 7, 2001 | 01:52 PM
oldcam82's Avatar
Engine is a 350 with 327 heads valve where
adjusted properly and engine run just fine.
When on the road and accelerating between
1500 to 3500 rpm there this noise that is like valve knocks that disappear when not
accelerating or over 3500 rpm. Could it be
the ignition?
Old Jun 7, 2001 | 03:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That would be classic "pinging" or "spark knock".
Either back the timing off a little bit; or put an adjustable vacuum advance and curve kit in the distributor; or use higher octane gas; or get the engine's coolant temp down a little.
ICON Motorsports
pjsparts
Oct 29, 2025 06:39 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
dimented24x7
Sep 6, 2015 03:51 PM
Jlanz55
Sep 6, 2015 02:35 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
