How to connect PCV to open element?
Old Jun 4, 2001 | 07:54 PM
83Z28's Avatar
I got the edelbrock open element air cleaner today, and it has an adapter for the PCV valve. I was looking at it and can't figure out how it is going to work. Any help is appreciated.
Adam
Old Jun 4, 2001 | 08:31 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
The PCV valve does not go to the air cleaner.
The PCV valce should connect to manifold vac. at the base ofm the carb.
The kit they give you is for the breather hose from the other side valve cover. I usually just throw that away and run a push in breather.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Old Jun 4, 2001 | 10:19 PM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
not necessarily, in fact i will never run another pcv to manifold vacuum. it sucks the valve cover gaskets in and causes a huge vacuum leak. not to mention its completely unnecessary to have that much vacuum in the crankcase. your only removing blow by gasses, and if you have a breather on the opposite valve cover you would have plenty of airflow to remove them.
85 IROC 350 11:1keith blacks,.555lift erson roller cam,1.6 crane roller rockers,edelbrock intake,holley 4150 750dbl pumper, nitrous oxide,full length heddman headers,true dual exhaust, 11"stall converter, 700R4, 3.73 locker, certified engine and electrical systems mechanic
Old Jun 4, 2001 | 11:19 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
<font face="Verdana, Arial" size="2">Originally posted by bottledpower:
</font>
I won't get into an argument over proper PCV systems...what ever works for you is what you need.
Think about this though.....if you don't need that much pressure vented out of the crankcase..why do Pro Stock and a TON of other class drag racers run versions of air pumps set up to suck the gasses out of the crankcase?? How ever small (not that it matters on the street) the gain is, crankcase pressure costs horsepower.
Besides, PCV is a regulated vac. leak, it doesn't make the car run any worse. I can't say I've ever seen a valve cover gasket suck in because of a PCV valve...hmmmm
Just my opinion...
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited June 04, 2001).]
Old Jun 4, 2001 | 11:35 PM
Bort62's Avatar
Failing to Run an active PCV system will result In Super acclerated Oil fouling, and Decreased Engine LIfe, Just ask Vader
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 15.26 @ 87.0
Reader's ride -&gt; My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Jun 7, 2001 | 04:29 PM
83Z28's Avatar
Thanks for the replies. In the first post I should have said the pcv breather, not valve. I think I'll get the aftermarket one, but they confused me when they started talking about drilling holes and stuff.
Later,
Adam
GTAman
Jul 3, 2024 07:29 PM
tglennon11
Sep 23, 2015 05:30 PM
scotrans am
Sep 5, 2015 04:26 AM
luvofjah
Sep 3, 2015 07:08 PM
Slush92RS
Sep 2, 2015 08:56 PM
