burning oil /rings
Old Jun 7, 2001 | 10:36 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
burning oil /rings
hey guys i have an 88 305 motor with 70k miles on it, i have brand new SR torquer heads and a new performer intake, when i start it it doesnt puff any smoke, after a few minutes on fast idle it'll blow some light blue smoke, but not really that noticeable, if you open it up it'll blow light blue smoke and downshifting it blows smoke, i checked the pcv valve and its working fine, when i changed the heads the cylinder walls werent chewed up or nothing and there was barely a ridge at the top, i pulled all spark plugs and #5 and #4 are fouled with oil, all the rest are ok, so i did a compression check and while turning over, the #5 shot oil out of the hole on to the header... any comments on that? also the compression check is about 150 on all cylinders, could the rings be stuck on these pistons? the engine makes no noise and has a lot of *****, what about an engine flush? or transmission fluid in the oil? i dont wanna pull this motor again, i just wanna drive it. thanx
86 Camaro with 88 305 LB9 using 86 carb setup, edelbrock performer manifold, 305 S/R Torquer Heads, Hedman Headers, Crane Compucam 2032 edelbrock cat-back, gutted cat, slp underdrive pulley, mallory ignition, 305 h.o dual snorkel air cleaner, hypertech thermomaster chip,160 degree thermostat, 5-speed, 3.23 posi
95 Beretta Z26, 3100 V6, 4 Speed auto, stock
db057
Apr 28, 2019 07:45 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Billgluckman
Members Camaros
36
Nov 24, 2015 07:29 PM
my86bird
Oct 23, 2015 12:20 PM
CatmanFS
Sep 19, 2015 09:00 AM
