what am i missing here?
Old Dec 7, 2004 | 11:16 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
ok, in my engine bay, to the front of the distributor's remote coil and all that junk, is a metal disk shaped thing that connects to a tube(s?) going to the exhaust and throttle body. im assuming this is my egr, all signs point to yes. to the front of that and on a lower elevation is a similar looking plastic thing(circled in green) that has a vacuum connection. that is connected to two pipes that go to the exausht(if i recall correctly), and one that goes to the front of the engine, and apparently into the block(below the throttle body, definitely not into). the vacuum line that i assume leads to this has been burnt on the manifolds, possibly intentiionally(to plug it), probably accidentally. the line is the tiny hard plastic type, and is completely sealed by meltedness.
my question to you is: what am i missing by that being disconnected?
i cannot tell where the vacuum line originates from because it is wrapped up in the wiring harness and carried off somewhere.
'89 firebird 2.8l mpfi v6 700r4
oh, and if my drawing is too confusing, maybe tomorrow i can go out and take a picture.
Old Dec 8, 2004 | 12:12 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Off hand it sounds like you are referring to the EGR valve and the EGR solenoid. The solenoid would have the two plastic vacuum lines that you are describing.
Old Dec 8, 2004 | 10:28 AM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
That looks like something from andy reed's playbook.
Old Dec 8, 2004 | 10:50 AM
BirdofFireBOB's Avatar
Car: 88formulatp1
Engine: 5.0
Transmission: 5
The black thing is Brown's stadium, and the green thing is Davis's exit route...??
Old Dec 8, 2004 | 11:20 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
are the blue lines, coolant lines? it seems to be the heater valve.
Fireslash
Apr 11, 2016 06:43 PM
sammy52401
Nov 11, 2015 07:20 PM
BrianI
Oct 3, 2015 12:57 PM
Numbah-1
Oct 2, 2015 08:27 AM
lewandom
Oct 1, 2015 08:15 AM
