Fresh rebuilt engine installed.. won't start, only chuggs
Old Jun 8, 2001 | 04:16 PM
spearson's Avatar
I have an 89 IROC 350, had the engine rebuilt.
Finally got everything hooked up and got it out to try to start today, well it didn't start. I am thinking it is a timing thing, but we can't seem to get it adjusted properly. It turns over and over chugging wanting to start, but won't. After an while of fiddling with it we left it alone for about an hour (it was flooded, gas in the oil now) .
Well after an hour we came back played with the timing for a sec and it started!!, but it was backfiring through the intake and died quickly. It did that for the two times it shortly ran. After fiddling with the timing a little more we get nothing (probably flooded again).
Here is what we think:
Coil is going out? When we tested for spark, the spark plug was lighting an orange spark. Isn't it supposed to be blue?
Timing a little off still
Rocker Arms too tight..
It has plenty of fuel pressure.
Any of you have any idea's or suggestions? I would really like some feedback on this as we are getting frustrated.
Steve
[This message has been edited by spearson (edited June 08, 2001).]
Old Jun 8, 2001 | 04:45 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
tight rockers will definately do it.. loosen and see if that helps.
Old Jun 8, 2001 | 05:47 PM
Blueiroc's Avatar
If it's backfiring through the carb it is most definately timing, make sure the timing isnt 180º out of phase....but definately timing related.
-BGrian
Old Jun 8, 2001 | 08:19 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
I agree with Blue....If it's backfiring, it's a timing issue.
[This message has been edited by 406TPI (edited June 08, 2001).]
Old Jun 8, 2001 | 09:39 PM
spearson's Avatar
When we first started, turning the engine over would make it backfire through the intake, and it was 180 degrees out. We fixed that, It sounds better now, wants to start but doesn't. When we got it to run for about 10 seconds it ran pretty good, but started backfiring through intake. If I have sometime this weekend, I will take the valve covers off and slightly loosen those rockers.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Mar 5, 2017 06:37 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
justin57
Aug 20, 2015 07:05 PM
