Quick help removing side ground effects
Old Jun 9, 2001 | 10:23 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
What holds the back corner in?? Are there hidden bolts like the ones under the emblems in the front? Possibly behing the interior panel??
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Old Jun 9, 2001 | 11:42 PM
UVA3rdGen's Avatar
They are just about as hidden as they can get. You have to take out those side panels that sit behind the passenger and driver seats where the coat hanger rack is. After you do that look down low againt the body and you should see a bolt sticking through with a nut. It is a real pain to get off, but that is the last bolt you are probibly looking for.
Old Jun 10, 2001 | 07:31 AM
Car: 89 IROC-Z
Engine: 383
Thanks.
Frozer!!!
Jan 19, 2024 04:55 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Street Lethal
Aug 14, 2015 08:25 PM
92firebirdchris
Aug 14, 2015 11:56 AM
3rdgenparts
Aug 8, 2015 07:09 PM
