Removing Smug Pump
Old Jun 10, 2001 | 02:11 PM
SpeedStar's Avatar
Removing Smug Pump
Will this make all the other Emission sensors go crazy like the O2 sensor. I going to take it off and I was just curious.
1991 Camaro Z-28 305ci 230hp
1985 Camaro Coupe 331ci 300hp
http://www.geocities.com/speedstar38...Speedstar.html
Old Jun 10, 2001 | 02:31 PM
Stuart Moss's Avatar
No.
Old Jun 10, 2001 | 02:38 PM
SpeedStar's Avatar
Cool Thanks!
Old Jun 11, 2001 | 11:04 AM
CamaroLuvnPunk's Avatar
<font face="Verdana, Arial" size="2">Originally posted by SpeedStar:
Cool Thanks!
</font>
Hold your horses...... pending on if you like that orange light saying "Check Engine" on at all times then go for it.
However if you have to go to the sniffer test soon..... if at all.... then just remove the belt part. With a Serpintine pulley system it ia harder then V-Belts.
Erik
1983 Berlinetta Camaro with a 305 4brrl Carb.... soon to have TBI,Electric Fan, Serpintine Pulleys and if I can find one... a LT1 Cam.
Old Jun 11, 2001 | 11:14 AM
SpeedStar's Avatar
We don't have the pleasure of emissions tests here in Wyoming. And I'm not to worried about the Check Engine Light!
Old Jun 11, 2001 | 01:02 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
I took off my smog pump over a year ago. I have no problems and my check engine light doesn't come on, and yes it does work because it has come on since for another problem.
Old Jun 11, 2001 | 02:56 PM
Guest
Guest
Posts: n/a
The check engine light wont come on from removing the smog pump and related hardware, the ECM doesnt recieve any signals from any of that stuff, so it has no way of knowing if its there or not.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
backtothe80s
Sep 5, 2015 12:39 AM
NBrehm
Aug 25, 2015 11:49 PM
3rdgenparts
Aug 8, 2015 07:09 PM
