CRAP! - cap screw rod bolt touches cam lobe
Old Jun 10, 2001 | 01:05 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
Thats exactly why I got the ones I did, they weren't supposed to need clearancing. I had allways heard that it was only number 2 and 6 rods that touched. I don't know for sure but the others might also touch. I guess I am going to have to put one in at a time and see. But, if I am going to have to remove material, I guess I should do it to all rods.
Old Jun 11, 2001 | 06:13 PM
Vader's Avatar
JCB,
If you want to maintain any kind of balance, you'll need to cut all bolts the same. Are you stroking the engine?
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jun 11, 2001 | 06:45 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Is that interferance with the cam installed and degreed in?
Old Jun 11, 2001 | 07:13 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
its a 400 with 5.7 rods. Yep, i found out when I was checking the piston to valve and degreeing the cam. I had used the same cam in a previous shortblock that had 5.7 X rods. The corners of the bolt heads on #2 and #6 had been touched but that is all.
I sent scat an e-mail in hopes they would tell me how much is safe to take off (acutally probably none but). The threads are pretty close to the top hole. The motor was balanced already.. it balanced up with 1709 grams bobweight. i had hoped to have it very light with really strong parts but i got screwed on that deal.
I think there is enough to remove without any problems.
Actually, i just looked closer at the X rods, number 1 and 5 had also been ground. maybe I can look at the ones that had been cut and get a general idea how much i need to take off.
[This message has been edited by jcb999 (edited June 11, 2001).]
Old Jun 11, 2001 | 07:44 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
man the bolt heads are cut a lot. I can't see doing that to the new rods. especially all 8 of them. ....
blast,, i am at least going to need new pushrods with the reduced BC cam. I might as well go solid roller.
I am kind of pissed at www.dynoflo.com. He could have said something about a reduced BC cam when i got all this stuff.
1992 Trans Am
May 10, 2023 07:19 PM
junkcltr
Aug 2, 2019 11:12 PM
camaro71633
Sep 1, 2015 10:24 AM
cstrobel65
Aug 15, 2015 10:19 AM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
