Fuel line & Headers
Old Jun 13, 2001 | 08:04 AM
Alan84TA's Avatar
Fuel line & Headers
I put Edelbrock TES headers on my '84 L69. On the passenger side the header almost, if not, tuches the fuel line. I put high temp wrap on it but I don't trust it. Its so close I'm afrade the header might crush the line if the engine shakes much. My question is. Would it be ok to cut that piece of line out and replace with rubber line and run it up higher?
Old Jun 13, 2001 | 08:19 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i had the same problem with my hedmans, i put some heat shield around the lines, hasnt done anything yet, i dont know if you can just cut the lines, there flared, so they dont leak.
86 Camaro with 88 305 LB9 using 86 carb setup, edelbrock performer manifold, 305 S/R Torquer Heads, Hedman Headers, Crane Compucam 2032 edelbrock cat-back, gutted cat, slp underdrive pulley, mallory ignition, 305 h.o dual snorkel air cleaner, hypertech thermomaster chip,160 degree thermostat, 5-speed, 3.23 posi
95 Beretta Z26, 3100 V6, 4 Speed auto, stock
Old Jun 13, 2001 | 02:58 PM
giovanhalen's Avatar
Car: 1984 Z28
Engine: 454
Transmission: Th400
You could cut and use hose if you want. I wouldn't be too worried about the engine shaking and hitting the line but all that heat could vaporize the fuel.
Old Jun 13, 2001 | 05:49 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
IMHO about the worst thing you could do would be to put rubber line in a hot place like next to a header.
Get up under the car; in the very center of the trans tunnel, above the bell housing, you will see a bracket that holds the line in place. Make sure the line is in the bracket. If it is in the correct place and still seems too close, bend it so that the part that goes up to the "frame" is farther rearward.
ICON Motorsports
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
mdtoren
Aug 23, 2015 12:52 PM
AkDrifted
Aug 17, 2015 07:45 PM
