Ok need help
Old Dec 25, 2004 | 10:30 AM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
Ok need help
Ok i did what you guys said discconnected the maf and it still did what its been doing....
SO i moved on....
I disconnected my Accell HEI Super Coil and thought, hmm what a good way to prove i'm getting np spark then to remove the coil and try starting it and it turned over but did the same darn thing, just turned over.
So its defiantely not getting spark...
SO while dissasembling the Cap, noticed on a couple(2) plugs my step-father back in the day forgot to put grease on those connectors and they had turned a dry white color from corrosion, thats not good is it...
Well so i took the old ignition module out and i replaced it, I used lots and lots of thw hite grease it gave me as per you guys tend to tlel people that a lot in the forums i've read...
as i reassemble the dizzy. are there any things in particular i should look for?
Right now i'm taking abreakfast break.
Also, i'll search if noone post quick enough, what is the correct order to hook these wires back up to the cap, i sorta forgot to mark them, but the order is normal so. if you could post it that'd be greatly appreciated....
Shane
Thanks,
Shane
Old Dec 25, 2004 | 12:14 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
Re: Ok need help
Shane
Thanks,
Shane
dude first of all you need to search first before posting and the plug order thing that would take you 2 seconds to find anywhere i just cant believe you are now asking for the plug order whats next which way to turn the ignition to start the car?
its christmas celebrate it
Old Dec 25, 2004 | 12:44 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
ok i found the plug order on ym own, anyways, i reassembled everything to the exact way it was, excluding the plug order i put it to where it should be, whether it used to be or not.
Then i tired cranking the darn car and still nothing, the battery is running low, it barely cranked over the motor, so i need to charge it now...
goona go out now and start probing with my check light...
Old Dec 25, 2004 | 01:10 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
What do you mean by whether or not, it was correct or not? If the car ran before you took everything off, then you should have installed everything the way you took it off.
Did you remove the distributor at all? If you did...it is highly possible that you are 180 out. I have ran into this problem several times.
Old Dec 25, 2004 | 01:15 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: Ok need help
This is by far the stupidest thing I have heard today. If it doesn't start, yea pull the coil. If it doesn't start, yup the coil is bad. Get a damn clue.
Old Dec 25, 2004 | 01:21 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
ok, 180 out, ok the rots thingy, for some reason i think i 180d it by putting it in reversly the way it was..... so i'll go and try it 180 from now and see....
i never pulled out the dizzy, just the cap, rotos, and coil.... oh and i replaced the ICM....
Old Dec 25, 2004 | 01:33 PM
rustybluebird's Avatar
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
Will somebody drive to this guys house and break his keyboard please. At first It was funny but now it's just plain annoying.
therkid, grab a ****ing brain.
Old Dec 25, 2004 | 01:43 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Re: Ok need help
The idea of the search function is to save us (the TGO body) from pointless threads like this. Oh wait, thats about every damn thread that comes from your direction.
Install a brain.. make sure it doesn't go in 180° out.
Let's think abou this for a minute. You never removed your distributor. But you're going to just try turning it 180° anyway? Do yourself a g0ddamn favor. Go celebrate Chrismtas. Forget about your damn car. When the season's over, give yourself a gift. Bring your car to someone who actually knows what the hell they are doing.
I agree with LJ in the other thread. Get a Honda. No third gen deserves to be subject to sheer stupidity such as you are implimenting upon yours.
