Fuel pump?
Old Dec 26, 2004 | 01:44 PM
timbuck2's Avatar
Car: 1992 Camaro RS
Engine: 6 cyl
Fuel pump?
Engine back fires at times while trying to accelerate mainly while at low speed or from a stop especially when cold. But can happen when engine is hot also. other times once engine is warm accelerates without hesitation. Mechanic said fuel pressure was very low and that fuel pump needed to be replaced to start with but that the problem could be the pressure regulator? 1992 rs 6 cyl 138,000 miles new cap,rotor,wires,plugs,fuel filter.air filter.Can the pump have intermitent problems and cause this or does it sound like a contact problem with wires? Or something else? Any suggestions? Please and thank you for any insight. Engine pulls no codes.
Old Dec 26, 2004 | 02:27 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
What is the fuel pressure? I would start with the FPR before I even considered changing the pump, much cheaper and easier/faster to do.
Old Dec 26, 2004 | 02:34 PM
timbuck2's Avatar
Car: 1992 Camaro RS
Engine: 6 cyl
I believe the mechanic said 4 or 14 psi but some one told me that would not run the engine.
Old Dec 26, 2004 | 04:38 PM
kevinc's Avatar
Car: 1982 Z28
Don't take this the wrong way. If you've got a mechanic working on it, that implies you don't work on it yourself. What exactly are you going to do with the answers you get here?
If you have to provide mechanical info to your mechanic, he's not the guy you want working on it.
If you're going to start wrenching on your car yourself, that's great. Get a fuel pressure gauge, do a search in the V6 forum to see what fuel pressure should be, and go see what yours has.
Old Dec 26, 2004 | 07:40 PM
timbuck2's Avatar
Car: 1992 Camaro RS
Engine: 6 cyl
I`m trying to do the work myself(where possible), when the mechanic said he wanted $1200.00 to replace the fuel pump and sending unit for the fuel gauge I promptly took the car out of the shop. The car drives fine 80% of the time, so its not a emergent situation, so i will take your advice and go from there. Thanks for your thoughts.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
