tires chirping
tires chirping
I have A 1990 camaro 3.1L . when I go to make turns without pressing the brakes it ,makes a chirping sound. I enjoy high speed cornering , what can I do to stop this from happening
The chirping is probably caused from the tires sliding.
With that said, anything to improve traction should help. Better suspension, wider tires, etc.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
89 iroc-z 305 tbi
Car: 82 camaro SC
Slow down or get a performance suspension.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkim bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
82camaro
Get Better Tires, Costco Special Won't Cut It.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 15.26 @ 87.0
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
