Aftermarket Valves and Valve Seals
Old Dec 29, 2004 | 10:06 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
I just recieved my set of aftermarket stainless valves today. They have only one ring on them, which is for the lock. They don't have a second ring for the seal to go in like the stock valves do.
Do I just put the seal on in the same spot as stock? No Seal? Against the lock?
Old Dec 29, 2004 | 10:16 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Most aftermarket valves (companies) are good enough to know that positive seals are the best. O-ring seals are questionable, at best. Fel-pro makes a posi-seal that deoesn't require machining of the valve guide.
Old Dec 29, 2004 | 10:24 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
Do I just tell the parts store I need fel pro "posi seals" or ??
Old Dec 29, 2004 | 10:28 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
I've listed the part numbers here:
https://www.thirdgen.org/techbb2/sho...ghlight=felpro
Any Parts America store should carry them.
Old Dec 29, 2004 | 10:50 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
Alright, thanks. That thread made me a little confused... Should I use the intakes on both exhaust and intake or, use the intake on intake and exhaust on exhaust?
Old Dec 29, 2004 | 11:18 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
Another quick question... i've never used this type of seal before, do I put it towards the top of the stem, next to the lock, or do I put it at the bottom near the guide?
And these should work fine on an non-machined older style head, correct?
Thanks for all your help!
Old Dec 29, 2004 | 11:53 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Just coat it and the valve stem in a bit of oil and slide it on. It pushes all the way over the guide boss.
A little help in my sig...
deracer
Apr 11, 2016 12:04 AM
Magman
Sep 12, 2015 10:43 PM
gixxer92
Sep 1, 2015 04:32 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
g.l.mos
Aug 22, 2015 12:02 AM
