Digital dash plugs
Old Jun 15, 2001 | 04:50 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Digital dash plugs
For those of you who have swapped out your analog guages for the digital guages... I know that the two diag panels won't work w/o the new harness, but are the plugs for the oil/temp/volt/speedo/tach/blinker/brights/ses/brake/security...(the vital essentials) the same? I think they might be I was just going to check before I pulled. I just want to test this dash to see if it works before I pull my entire harness. Work is being done on car in signature.
Mint black/black 1987 T/A GTA 305 5-speed, 55K,
3.45 factory POSI,SLP cam, SLP runners, Taylor wires, hurst comp plus shifter, K&N conical rig, AFPR, coated shorty headers, no cat, no smog, 3in. mandrel-bent single exhaust, flowmaster, TB air foil, 160 stat, SFC's, lower control arm adapters, Aluminum Driveshaft, ported upper and lower, Mobile ES and 10 disc, kickers all around and q-logic kick panels...Perf 350, rear batt, lowering springs,cowl hood, & NOS coming soon!
The_Phoenix
Feb 4, 2016 07:10 AM
Pilotrick50
Sep 2, 2015 12:48 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Sanjay
Aug 12, 2015 03:41 PM
beachrodder
Aug 7, 2015 04:27 PM
