Fan switch location? How hard to get to?
Old Jun 15, 2001 | 09:00 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Hey guys I know that you all said that on an 89 GTA that the fan switch was near the passenger side head, but how hard is it to get to? can I see it from the top of the engine? Can I get to it easily from the bottom with the car jacked up? And are there any helpful hints or tricks to this? I just got a 170 thermostat, and a Hypertech fan switch, that comes on at 200 degrees, and off at 185.
Thanks for the help people!
See ya
Mike
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber.
Old Jun 15, 2001 | 09:04 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
It's easier to get to, IMO, from under the car - just be advised you might get a little wet, as water/antifreeze will spew out a little... the switch is between the #6 and #8 plugs... easy to get to. and yes there is a 200 on/185 off switch... can be had thru Jegs or Summit, maybe local...
KAM
Sorry, just saw you said you had the switch, so scratch all that... it's between #6 and #8...
[This message has been edited by thunderstick (edited June 15, 2001).]
Old Jun 16, 2001 | 12:13 AM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
I had to remove my starter to get to that switch...it was just so much easier and faster.
'89 Formula 383 TPI
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Pilotrick50
Sep 2, 2015 12:48 PM
TA8487
Aug 16, 2015 12:21 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
