BBC casting #'s.......??
IU just bought a complete engine from a known racer here in town and was told that the motor was a 454 Chevy, but the info that I'm getting from the net is that it's a 396. Can someone please correct. Here are tha casting #'s 3969854..
thanks..
BTW: wich flexplate do these use (i need to know to get me a starter) and if they are internally or externally balanced (need to get a dampner too!)
[This message has been edited by Baz89RS (edited June 17, 2001).]
thanks..
3969854....402.......70-72...2 or 4 bolt
That came from www.mortec.com. The 402 is a 396 bored .031 to 4.125 from the factory. For our purposes (I have one too) it's just a 396 with one less overbore availible. The plus side of the block is some of the older 402's have thick walls and will live happily at larger bore diameters.
You might check the crank #'s and make sure that it is a 3.76 stroke crank. It doesnt take much to put a 454 crank in a 396 block.
Thanks man,
I'll drop the pan to check the crank #'s out. what does a 454 crank make the engine?
the motor ran mid 11's in an el camino so it should be something strong. I'll post back as soon as I get a chance to drop the pan.
If that thing is bored .156 the walls would be paper thin, I couldn't imagine taking anymore off. I'm not saying it isn't possible, but it is highly unlikely.
When you take the pan off, look at the pan rails on the sides. To put in a 454 crank you need to grind clearance into those areas for the counter weights. Off the top of my head a 454 crank (4.00" stroke) and a 402 block (4.125+ any over bore) would be around a 425 CID. It wouldn'd be a 427 as we know it, thats a 3.76 stroke and a 4.25 bore, (e.g. 396 crank + a 454 block).
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
My books list that casting number as a 396 from 69-72 or a 402 from 70-72
Easiest way to check the crank to see if someone tryed to stuff a 454 crank into it is to look at the balancer and flex plate. A 454 is externally balanced and will have the offset balance on balancer and flexplate.
I doubt it's a 454. It's too much work getting the crank to clear and to bore out the block that much. It's cheaper to find a 454 block.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
92rsvortec350
19
Oct 9, 2015 09:39 AM
skinny z
Oct 5, 2015 06:23 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
