New throttle body......code 33 and 42
Old Jan 9, 2005 | 06:31 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
I swapped a BBK 58mm TB onto my '88 LB9. Within 15 miles, the car stumbled, then threw an engine light. Pulled the code and it's a 33 and 42. There's no vacuum leak. Does a higher flow TB usually throw a light? If so, I'm selling it. As for the 42, I haven't messed with the timing in months, and the EST wire is plugged in. What would the TB have to do with the timing advance? The TPS is adjusted correctly after the swap. Before I get flamed, I have done a search and got partial answers. Thx.
Old Jan 9, 2005 | 09:05 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Why not swap back and see if it throws the codes again? That's one of those things... many agree you don't need the big TB and it will cause problems, many agree you don't need the big TB and it won't cause problems. Then there are the 'others'...
Old Jan 9, 2005 | 09:16 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Your code 33 can be set by the larger amount of air being drawn through the MAF due to the larger throttle body that you now have installed on the car. The code 42 could just be an intermittent affair, clear the codes and drive it for awhile to see if they both come back.
Old Jan 11, 2005 | 09:46 AM
Engine: LB9/383
Well it kept coming back within 15 miles of driving, until I adjusted the TV cable again. Then it went away and hasn't been back. For kicks I took the cable out of adjustment and the light came back on. I don't know how, but for some reason the TV adjustment is tied into the ECM. Must have something to do with load vs. rpm and the ECM thought something was up with the timing. O well, it's fixed. Don't know if the TB was worth putting on, but I had it laying around.
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
HoosierinWA
Oct 7, 2015 10:15 AM
