Stumble, timing light shows a slight miss
Old Jan 12, 2005 | 07:19 PM
gonzo1028's Avatar
this is a 91 formula w/350 tpi Wow, I am stumped... Here is the problem, seems like it happens more often after it is warm, but sometimes even when it is cold. There is a stumble on acceleration, sometimes it gets worse, sometimes it is not there at all, however it does seem to be occuring more frequently. I have had it act up, got a chance to throw a timing light on it, it was missing slightly checked all plug wires and they all exhibited the same miss.
Here is what I have done, hooked up an obd2 found nothing out of the ordinary, tps is in range, cts is in range, o2s operate normal, I have replaced the ign. module, coil pack, plugs, wires, cap, rotor, map sensor. I am truely stumped and tired of throwing parts at it. Any suggestions would be greatly appreciated.
Old Jan 13, 2005 | 07:26 AM
gonzo1028's Avatar
no one??
no one has any ideas?
theshackle
Sep 17, 2020 08:26 AM
Andrew6.688
Dec 13, 2015 10:59 AM
Omega
Aug 10, 2015 12:46 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
Thirim
Aug 9, 2015 06:19 PM
