Need some help ...anyone
Old Jun 21, 2001 | 11:25 AM
senjorb0b's Avatar
Have an 87 305 camaro and it runs good but the problem is that the fan will not turn on, the connections are good and the fan works but it wont turn on automatically. what could be causing that?
thanks alot
andrew
Old Jun 21, 2001 | 11:46 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Fan switch
Pass side head between #6 & #8 plugs
ICON Motorsports
Old Jun 21, 2001 | 12:35 PM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
Check the fan relay and also check very closely all the wiring, including the weather-proof connectors.
My fans stopped working and like you said all the wiring looked fine, then I disconnected the weather-proof connector (with force) and found that the 12v "hot" lead terminal melted to the plastic connector. So, I re-wired it and fans worked fine.
Good Luck!
1987 383 cu.in. IROC-Z: TPIS MiniRamIII / GM FastBurn heads/ 10.6:1 compression
Comp cams custom grind: Dur'n 224/236 Lift .536/.555
Strange 12Bolt Diff./ Neil's Home-Built BulletProof 700R4+Vigilante 2800 stall converter
MSD Billet Distributor, Dig 6+, & Blaster coil
Hooker Supercomp Long tube headers
Abubaca
Jun 7, 2010 03:33 PM
5.7RamJet
Aug 12, 2007 11:54 AM
Abubaca
Jan 29, 2006 10:26 PM
SERENAs Z
South Central Region
Jul 23, 2004 08:36 AM
