What next?
Old Jun 22, 2001 | 11:27 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
What next?
Well I was just outside trying to change my trans mount (again). When I break one of the bolts to the crossmember, it sheard right off, no thread to look at just the end of it is sitting there. So, now what do I do?
Flowmaster,Edelbrock open filliment filter with K&N filter in it
160 stat, BF G-Force w-rated tires
Old Jun 23, 2001 | 06:54 AM
ede's Avatar
ede
i'd weld a nut a little larger than the bolt on it and see if you can get it out that way. if not my next move would be to drill it out with the tap drill and retap the hole.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jun 24, 2001 | 12:44 AM
Car: 92' RS
Engine: LO3
Well I changed the mount and as of now I have 3 bolts holding the crossmember on.
Any problem with having only 3 bolts on it? at least temporarily?
Old Jun 24, 2001 | 01:49 AM
87RS402's Avatar
No I don't see a problem with using 3 bolts temporarily. I used 3 on a temp basis when I did my first swap and had no problems.
You do need to get it fixed though...
