Steering Wheel- HELP
Old Jan 23, 2005 | 09:40 AM
hawaii's Avatar
Car: Camaro RS
Engine: 305 vin E TBI
I had removed my steering wheel to replace the ign. key. Now the shaft that the wheel sits on moves in and out.. Which way should it be? Tried both but still have lots of play in the steering wheel. the car does have a airbag and yes i reinstalled the cam lock or whatever that black thing is called. and when i move the wheel around the horn honks???? NEED HELP
Old Jan 23, 2005 | 10:12 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
You need to include more info. tilt or stationary column? etc...
This really should be on the body/interior board...
Old Jan 23, 2005 | 07:58 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Sounds like you didn't re-install the lock plate correctly... The lock plate is responsible for taking up the slack that exists in the upper half of the column shaft... I think you need to take it apart again and fix whatever went wrong (btw, that black part right before you put the steering wheel on is the airbag coil)..
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
