Is the ECM adding to much timing at idle?
Old Jun 25, 2001 | 04:35 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
I set base timing at 4-6* advanced. Reconnected the EST wire and the ECM added 20* or more on top of that. That can't be right can it, at only ~1000RPM's
Would it do this if it detected a lot of extra fuel?
Or it probably would do this if the TPS sensor was reading to high. Right?
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
