Yet another ring question
Old Feb 6, 2005 | 09:37 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
A couple of questions...
I bought a Eagle rotating kit to build my 383. I'm now to the point of installing the piston rings but, after opening up the box and laying everything out on the workbench, I dont know which ring is the top or intermediate. They didn't label the individual packages. After racking my brain I found the description listed on the inside flap of the box I took them out of, WTF!! The rings I have are Perfect Circle 4.00 +.035 1/16, 1/16, 3/16. One of the two have two pink stripes and a red stripe, the other has no color markings. Both have a dimple identifying the top. Anyone know which is the compression ring (top ring)?
Next, there are no instructions for setting or even checking the ring end gap on any of the lower four rings (oil ring expander, 2 oil rings and the oil rail support). Do I just install these blindly(not checking end gap) and trust they are ok or is there a specific gap required?
As always, thanks for your help.
Old Feb 7, 2005 | 05:36 AM
ede's Avatar
ede
end gap applies to the compression and scraper rings only you check and set the gap the same as any other ring. never have seen instructions about it on the package, any special consideration would be with the pistons. usually if not always the ring position is marked on the box
Old Feb 7, 2005 | 09:42 AM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Thanks Ede. Yeah I discovered that they marked the ring position on the box instead of the individual packages. It was just too late, I already laid them out to install them on the pistons then realized they were not marked individually.
From their website I was able to determine the differences and proper installation position by viewing the bevels (shape on inside of ring).
Since this is my ohhh, second rebuild ever, I didnt remember they mark the inside of the box. Doesnt make sense to me, they should simply put a description tag on the packaging the rings come in, it could simply say TOP RING / SECOND RING. I'm all set now, just lost an evening of otherwise productive work! Thanks again.
Old Feb 7, 2005 | 01:42 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
It can be confusing. Most are marked with either dots 1 for compression 2 for scraper, oil rings only fit one spot so. Ive seen some marked with paint as well, pink top, green second.
hectre13
Dec 11, 2023 08:14 AM
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
JHX
Aug 29, 2015 02:30 PM
redmaroz
Aug 16, 2015 11:40 PM
