Almost there
Old Feb 10, 2005 | 09:50 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Almost there
Almost there.
Injectors and oil pump pickup shows up friday. That completes the block. Then I gotta cut up the car a little for the intercooler plumbing, and make all that work.
Prolly be running in a few weeks at most.
-- Joe
Old Feb 10, 2005 | 10:30 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Check this out...
http://go.mrgasket.com/pdf/DFI_cat.pdf
Scroll down to page 25 of the file. Note that the plenum and water jackets are raised off of the base.
Maybe next time?
Old Feb 10, 2005 | 10:44 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally posted by RB83L69
Check this out...
Maybe next time?
Thats a sexy manifold! Wonder what the cost is on that one .
I had good luck with the holley I fabbed last season, so I'll keep it around until I get sickof it. It's a bit on the ugly side, b ut picked up 10mph over the TPI.
-- Joe
Old Feb 10, 2005 | 11:03 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Summit p/n ACC-74140 (manifold only), $356.95. ACC-74139 (w/rails), $484.99. "Should ship by 3/10."
Old Feb 10, 2005 | 11:13 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
http://store.summitracing.com/defaul...h&Ntt=acc74139 With fuel rails
Has the bosses to mount the rails to cast in
Old Feb 10, 2005 | 12:41 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yikes. Thats expencive.
I think i'd rather get a carb version of the same intake and mod it myself, assuming it was much cheaper.
But in any event, i'll keep using my holley or now. Its just a 1205 port, but it works well with the blower.
-- Joe
