PIckup Coil in Dist.
Old Jun 27, 2001 | 05:38 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Hey I was reading a post earlier about replacing a Pickup coil. How hard is it to do this job can it cause the computer to go haywire with the timing.......Mine jumps 6* BTDC to 12* BTDC at idle and it will not idle on its own......I have to hole the throttle blades open.
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Old Jun 28, 2001 | 12:13 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Yes, I guess it could cause the timing to jump...actaully miss firing to cylinders at the wrong time.
To change, you need to pull the distributor.
Knock out the rollpin holding the gear on.
Whoops, first pull the stuff off that's under the cap (rotor, reluctor)
Then slide the shaft out, and you have access to the PU coil.
DO all cylinders timing jump around like that? And does it do it even woth the EST disconnected? I assume you have the EST disconnected when you notice the 6-12 change?
Have you verified there's no slop in the timing chain, distributor to cam gear mesh?
Old Jun 28, 2001 | 12:42 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
If the car won't idle due to a vac. leak or missfire, the timing will jump around as the idle jumps around.
Are you sure the jumpy timing is causing the bad idle, or is the bad idle causing the jumpy timing??
Sometimes its tough to tell.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
Eric-86sc
Sep 28, 2015 11:37 AM
