Fuel pump not coming on...
Old Feb 11, 2005 | 06:34 PM
91rsklown's Avatar
My 91 rs 305 sat for about 6 months, i cranked it every other week or so, but as of the other day, it will not start.
The fuel had been on almost empty (1/8th of a tank) and last time i tried to crank it the fuel gauge is reading full. I checked all the connections(that did not require dropping the tank), then went to test the pump....but there is no pin-g in the aldl harness...the wire is completely gone, not pulled out, not cut, but like it was never there.
I am assuming that it is a problem with the wiring or with one of the connections at the top of the tank since the guage is not reading as well. how would i check for voltage at the harness right before the tank( the part coming from the back seat area).
thanks
Old Feb 11, 2005 | 06:43 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Relays and fuses is what I would check first. Fuel pump relay is on the drivers side firewall (at least it is on my V6). There is also a inline fuse on the fuel pump i believe, forgot which AMPerage it is. You can test the inline fuses by simply tugging on them a lightly. If the wire slips out, the inline fuse blew and you have to replace it.
Old Feb 11, 2005 | 07:14 PM
91rsklown's Avatar
nm...im getting voltage to the harness right before the gas tank, so i guess it may be the connection at the fuel pump since the guage doesn't work either...i hate dropping these tanks....
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Jae992
Aug 27, 2015 09:07 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
