technical Q's on roller cam engines...
Old Jun 28, 2001 | 08:38 PM
james_fearn's Avatar
I'm doing a cam swap: ZZ4 cam into my new roller long block.
Does it matter which way new roller lifters are facing, oil holes forward, aft, inward toward nearest roller lifter? The appeared to be randomly positioned.
Is the cam thrust plate symetrical so it can be clocked any position the bolt pattern allows, as long as the correct side is facing the cam?
I didn't see a cam button. Is there one? or is it on the timing cover (didn't look)?
James
Old Jun 28, 2001 | 10:01 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Liters can go either way, as long as the retainer fits them.
With the factory's bizarre roller stuff, you don't need a button. That retainer plate that goes behind the cam gear serves that function.
ICON Motorsports
F.I. 57 Belair
Aug 23, 2021 01:09 AM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
