The best mods
Old Jun 29, 2001 | 09:32 AM
Red85TA's Avatar
The best mods
I have an 85 TA with the H.O, 5.0 and i have installed hedman hedders with true duals, Open element K&N, and i scraped my quadrajet for a holley 650 and it has made a very noticable difference in performance, i want to do a few more small mods to it to keep me satisfied for at least another year then i am going to get a new 350 to plant in her. What other kind of small mods have u guys done to yours without spending a fortune?
Old Jun 29, 2001 | 10:48 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If you got rid of the CC Q-Jet, then you really need a non-CC distributor also.
The cam, and a bowl job on the heads, would be the next thing. There's many HP lurking there. Try the Comp XE262 cam and their steel roller-tip rockers. You can get a kit from them with the cam, lifter, timing set, & springs, and another one with the rockers and pushrods; all that could be re-used on a 350.
ICON Motorsports
Old Jun 29, 2001 | 11:13 AM
RW91B4C's Avatar
How about a underdriven crank pulley and ran air, maybe some suspension work(traction) and weight loss.
91 B4C 305 TPI - SOON TO BE 383
TREMEC 5-SP, STOCK 1-BOLT REAREAND w/342 GEARS, K&N, AIRFOIL
EDELBROCK HEADERS, DUAL CAT TO HOMEMADE Y-PIPE & 3.5" SINGLE PIPE W/ FLOWMASTER, CRANK PULLEY, MSD, FUEL PRESS REG, COWL HOOD, WELD WHEELS
14.1@ 98MPH
OTHER RIDE
67 CAMARO - STREET CAR, BIG BLOCK, PUMP GAS
350TH w/ATI 10", 12-BOLT w/373 GEARS
10.94@124.13 ON MOTOR - ET-STREETs w/MUFFLERS
starliner
Feb 9, 2016 08:18 PM
Quzyle
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
