Help with serpentine set up
Old Feb 14, 2005 | 05:17 PM
Jack G Jr's Avatar
Hey fellas I need pics or someone tell me do the belt go around the balancer or is there a pulley that bolts to the balancer?The reason I ask is that will be changing over to serpentine to run supercharger.and need a new balancer will go with ati's super damper will I need a regular damper or their serpentine damper. called them the guy I talked to seemed confused So I thought I better check with you guys first. Thanks
Old Feb 15, 2005 | 02:55 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
If you're runnin an L-98 the pulley bolts to the balancer, Lt-1 is part of the balancer itself. Most blower kits come with a crank pulley that has both serp and blower belt grooves in it. Unless of course its an lt-1 or if you are really lucky an LS-1.
Old Feb 15, 2005 | 06:34 PM
Jack G Jr's Avatar
Hey thanks for the info.Yes it's a L98 but wish it was a LS1!So does the blower pulley replace the stock pulley?
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
hydrolic144
Aug 29, 2015 04:14 PM
mustangdmurder
Aug 21, 2015 07:17 PM
jahblah
Aug 12, 2015 05:54 PM
