Hood Clearance w/various intakes....
Old Jun 30, 2001 | 10:25 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Will an Edelbrock Torker II and carb w/drop base air cleaner fit under the stock hood?
How about a performer RPM?
If not, are there any single plane intakes that will fit with a carb and Drop base?
Old Jun 30, 2001 | 10:43 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What kind of car? I forgot what you've got.
The only one I know of that might work is the Weiand Stealth part # 7525. That should fit if it's a Camaro. If it's a Firebird, I don't know. I would not recommend using a Torker II for anything; the car will go faster with a Performer RPM. There's been alot of dyno test results running around that have shown that. The older design intake is simply outdated.
Watch out for the "drop base" air cleaners. It hardly matters how tall the filter medium is, or how good the intake will flow, if the lid of the breather is lowered to 1" off the top of the air horn, which of course is what will end up happening if the manifold and carb are too tall. You end up just moving the restriction from under the carb to above the carb.
ICON Motorsports
Old Jun 30, 2001 | 11:09 AM
Formula-91's Avatar
I run the Torker II under a stock 91 firebird hood. It fits with the drop base air cleaner, and the N2O plate. The RPM will not.
Old Jun 30, 2001 | 12:51 PM
Engine: LT1, L400
RB,
'83 T/A. I would like to get a manifold, (I already have a Carter 650 CFM Carb) and go to the strip on a T&T day, make afew passes, then swap my CFI for the carb/intake combo and see how much the CFI is choking my engine. But I want to get a manifold that both fits under the hood, and works with my poor-man's engine combo. The sig has most of the details. Thanks.
'83 Trans Am: 400 CID oil burning junkyard long block, 224/234 crane cam, Summit aluminum roller rockers, hand ported intake, home bored 2.09" (53mm) throttle bodies, MSD 454 injectors(75 lb/hr), Holley 255LPH fuel pump, custum modded FPR, Edelbrock TES headers, SLP 3" stainless steel cat back, stock ECM & chip. Borg/Warner T-5 World Class, 12" Corvette rotors and clipers, GTA 16" wheels, South Side Machine subframe connectors, 1LE sway bars, 3.45 ring and pinion, Alpine sound.
Best E.T. 13.532
Best MPH 102.24
Old Jun 30, 2001 | 02:43 PM
Bort62's Avatar
the performer RPM spreadbore fits udner my Stock Camaro hood, But barely. When I torque the Motor It smashes the air cleaner into the Hood.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 14.82 @ 91.1 (faster than Ed)
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Jun 30, 2001 | 05:33 PM
Guest
Guest
Posts: n/a
A performer RPM and carter with a drop base air cleaner had 1" of clearance to the hood on my 86TA... plenty.
Old Jul 1, 2001 | 05:57 PM
Engine: LT1, L400
Thanks Guy's. Performer RPM it is. Now to just find a decent on e on Ebay....
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
