350 is studdering BAD?
Old Jul 3, 2001 | 08:30 PM
Chris 611's Avatar
Today when I got into the car to go to work it has a real bad studder when I take off. It is worse when the engine is under load at lower RPM's. You can feel it at higher RPM's (above 3000RPM), but its not as noticable. The studders get closer together as the RPM increase. When I put the car in neutral and rev the engine there is no sign of the studder, only when its under load. I used the timming light and all the plug wires are getting spark. I haven't checked the plugs yet. Any help would be greatly appreciated. Thanks.
Old Jul 4, 2001 | 12:47 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
One cylinder is not running.
Check the plugs.
ICON Motorsports
Old Jul 4, 2001 | 09:30 AM
Chris 611's Avatar
Thanks. While checking the plugs, I noticed that three of the plug wires were laying on the headers. I replaced those three secured all the wires out of reach of the header and the problem is solved. Good lesson I guess, make sure the plug wires are secured.
Frozer!!!
Jan 19, 2024 04:55 PM
Eric-86sc
Aug 24, 2015 09:01 PM
neekolzun
Aug 24, 2015 04:59 PM
Out-Cast
Aug 17, 2015 10:57 AM
